Farmall Engine Block Question
Hey Everyone,
I have a Super C with block casting numbers of 354898 R1. I found a block with casting numbers 251068 R1. With this block be usable on my SC?
Thanks
Usable yes, right sized maybe. A engine size for a Super C is cast into the engine on the distributor side. It is near the oil filter. It would be in
the form of C 113, or C 123 The 123 is more powerful, but should bolt in. Both need a hydraulic pump mounting hole under the distributor drive. Jim
Thanks Jim for the information. I luckily got a Super C block given to me this evening so I will certainly measure twice and check everything out. Again thank you!
