farmall b serial no.
lmnebr
just got a farmall b but a hydlrolic res.is under the seat. I cant read the
serial no. no. on the block is 6842DH what do i have need to order a valve train kit
The 6842DH is a casting number. You should look for the serial number on the engine block. It should stamped be on a raised boss, on the right hand side of the engine, below number 1 spark plug, behind the magneto and the rod from the hand control to the governor.
Picture of Engine Serial Number Location
I would remove the head and take measurements you have no way to know if the head is original over the yrs things change someone could have went to a newer head
