Hello guys, trying to figure out what s going in here. I can t for the life of me remember if my late father, had this Super M converted over to 12V, the generator is Stamped 12, 12 volt ignition coil and yet the part that s stumping me and I won t attempt to put power to it until I know for sure, the Long battery cable that goes to the frame, has the larger eyelet in the cable end like it fits the larger Positive post on the battery, whereas the battery cable that comes off the Starter button at the instrument cluster has the smaller lead end like it wants to fit the negative of the battery.
Also, the short wire going to the side of the Distributor, should that not go to ground/negative terminal of ignition coil ??
Really appreciate the help.
Thank you
Thank you
