Forrow wheel adjustment
i am not sure that i understand your question. i have a c with a trailing plow. the right rear wheel sits in as close as you can get it. i discover that , when you slide the rear wheels, if you have the wheel either a little high or a little low, depending on which way you want to move the wheel, it helps. also, a bit of oil on the axle and turn the wheel, where the fixed portion of the clamp is on top.
