International 444 sparkless
Gary
04-10-2001 04:39:25
I have an international 444 gas tractor. While boxblading the tractor just shut down. I've checked the fuel, drained the carb, drained fuel line, pulled dist. cap, checked rotor, pulled spark plug, checked for fire. No Fire. Pulled sheet metal off tractor and checked wiring with no sign of a short. Coil sounds like water in a half full fruit jar when you shake it. I'm in the process of getting a new coil but 60 miles from a store. Do you think it might be something else? The tractor has had most of the wiring cut although the oil pressure, temp, and amp gauges work. The tractor will roll over but not start.
Haas
04-10-2001 05:28:50
 Re: International 444 sparkless in reply to Gary, 04-10-2001 04:39:25
As I recall, on the 424 I had, there was a safety switch on the clutch. The clutch had to be depressed before you could start it. I think the 444 would be the same. Have you checked that switch?? Don't recall if if kept the starter solenoid from engaging or not, but I know it kept the ignition from working.
Gary
04-10-2001 15:06:24
 Re: Re: International 444 sparkless in reply to Haas, 04-10-2001 05:28:50
Haas,
Thanks for the reply however, the safety switch has been terminated. I think it is the coil or condenser.
