Good morning, I am in need of some assistance from the folks who know. I have an IH 574 that does not want to start. I parked it two years ago by the barn and finally back at chores. But, the tractor is very angry at me. I was finally able to drag it with my F250 so a position I can work on it. And as a side note, I was unable to drag it with the tranny in reverse only natural. Not sure if that is normal or an indication of a problem. Anyway, when I try to start the tractor the fuel gauge pegs to the right, I hear what I believe to be the starter attempt to do something. Thug, but no attempt to turn over. I ve followed the advice from other threads, had the battery verified (replaced, was no good), removed solenoid and starter and had them checked (depending on the folks that checked them), good to go, checked the safety switch at the clutch lever, good. As another side note, I see electrical tape in the area of the voltage regulator. Suspicious as I have no clue when that was done. Purchased the unit used 12 years ago. Any thoughts on where I should go from here? I have the schematic and plan on taking some voltage readings but I do not have the knowledge to know if the readings are correct or not Thanks in advance for you time and consideration. Keith
