Company Logo Shop Now
Farmall F20
FarmallLovinGuy
08-20-2019 16:43:32
Had my F20 running just last night. I took the carb off to replace the gasket between the manifold and carb. Got that buttoned back up and made a minor adjustment to the governor. Didnt mess with anything else. Now it won't start. It'll fire a couple times (enough to produce a little exhaust) then it dies almost immediately. Any ideas? Thanks.
rustred
08-20-2019 18:16:27
 Re: Farmall F20 in reply to FarmallLovinGuy, 08-20-2019 16:43:32
All depends what this minor governor adjustment was. Maybe the carb butterfly is staying closed.
Janicholson
08-20-2019 18:05:54
Make sure the gasket is sealed. If the flange on the carb or manifold, or both are not flat, the new gasket could be worse than the original. Sloshing the carb around can stir up crud from the bottom of the bowl, making simple into difficult. Jim
oldiron29
08-20-2019 18:03:46
May be that new gasket did not seal and you have a vacuum leak?
or you turned the carb upside down and stirred up some Sediment in carb bowl? How about throttle linkage not connected right?
FarmallLovinGuy
08-20-2019 19:09:30
 Re: Farmall F20 in reply to oldiron29, 08-20-2019 18:03:46
Well I disconnected the throttle linkage. Made sure it was going to mesh and hooked it back up. Started up on the 2nd crank, but now the tractor won't idle down. Seems to be running full bore even with the throttle at idle. Mine is a 38 with the factory variable speed governor. I assume the weights should be able to open at idle and should be pushed shut at full throttle, is this correct? Thanks.
Ken Christopherson
08-21-2019 05:33:56
 Re: Farmall F20 in reply to FarmallLovinGuy, 08-20-2019 19:09:30
Sounds to me like the governor linkage to carburetor throttle shaft is not in alignment. It is being held wide open because the tab on the linkage isn't in alignment.
farmaller
08-21-2019 16:35:48
 Re: Farmall F20 in reply to Ken Christopherson, 08-21-2019 05:33:56
I agree with Ken, that's what makes the most sense to me.
rustred
08-20-2019 19:39:16
No,...the weights are closed at idle or slow rpm, as the speed increases the weight fly outward opening the throttle.
FarmallLovinGuy
08-21-2019 14:17:15
 Re: Farmall F20 in reply to rustred, 08-20-2019 19:39:16
So I took a look at the governor, and when it is throttled down with the butterfly closed, the governor thrust mechanism is allowing the weights to fly open. And when the tractor is at full throttle, the thrust is pushed all the way back holding the weights from opening. So I'm not sure why it is the opposite of what it should be.
rustred
08-20-2019 20:39:54
also if the engine is stopped then when throttle is advanced it should open the butterfly. it should be doing that. plus the springs are holding the weights in also. when running the governor is actually pulling the throttle to the closed side. the springs are acting against the weights.
Janicholson
08-20-2019 18:06:28
Well that was interesting! Jim
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only ... [Read Article]
Latest Ad: Green magazine back issues for sale, in good used condition, some of the covers have mild chaffing. Have years 1991, 1992, 1993, 1994, 1995, 1999, 2000, 2001, 2004 and 2006 years available. 12 issues per year. 10 dollars plus shipping per year. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
