I put a mag on my cub and plan to start it by crank. Does it hurt to run it with no battery installed?
The field would be grounded thru the regulator calling for more generator voltage but the bat terminal would never be satisfied with no battery to charge.
I read 7 volts at the generator output with either the battery connected or not connected. Would that put a load on the generator if it never connected to the battery?
