Tractor has been running fine. This morning had to have the choke open a bit like it was cold outside. Had to continue with the choke so I thought maybe something in the gas and it would work itself out. After about 10 minutes of mowing the tractor just quit like it run out of gas. It would restart but only run about 3 seconds and quit again. Gas tank is full. Pulled the plug in the carb and had lots of gas running. I let it run a couple of minutes in case water was an issue.Tractor still starts, runs a couple of seconds and quits. Really thought it was a fuel issue when it originally stopped but can't imagine this is a fuel issue at this point after the flow out the carb. Can it be electrical. Tractor is 12 volt with a 6 volt coil and a resistor. I have 6 volts to the coil so electrical is good to that point. Tractor is sitting out in the field so I'm not going to try anything else until my wife gets home tonight and can help me tow it home.
