I have a 49 A farmall, i put electronic ignition on it with a new flamethrower coil. It is still 6 volt positive ground. It runs great for about 15 minutes then spits and
sputters under a load. It will run fine if you let it set for a while. It is not the fuel cap vent, it seems to be getting plenty of fuel but choking it does make a
difference. Any help would be appreciated, thank you.
