Company Logo Shop Now
TractorLinks.com
Steering wheel
dave01
08-13-2019 12:38:04
Hello, I have a 1951 Farmall super A I'm in the need of a steering wheel, What Dia. wheel did they use on this tractor, EBay offers a 15" and a 17-5/8" steering wheel both stating they fit the Farmall Super A.
Also what holds the steering wheel on? I'm guessing a big nut ?? If yes mine has been twisted off, What do I do about that ??
Thanks, Dave
Janicholson
08-14-2019 05:47:25
 Re: Steering wheel in reply to dave01, 08-13-2019 12:38:04
Another option in addition to the setscrew Gene mentions, is to center punch and drill the center of the broken shaft with a 5/16 drill, then tap the hole with a 3/8-16 tap. Use a washer or cup shaped washer and grade 5 bolt, to make sure the wheel stays on. Jim
gene bender
08-14-2019 03:06:58
15 inch was standard but the large one will make turning the wheel easier. Without the nut a new wheel will not seat tight enough and be loose might need to drill and tap a set screw on top of the key you just mite need another steering shaft I got one if you need it.
dave01
08-14-2019 18:37:26
 Re: Steering wheel in reply to gene bender, 08-14-2019 03:06:58
How much for the steering shaft with shipping to 13166 NY ?
Whats involved with changing that steering shaft?
Thanks dave
gene bender
08-15-2019 06:04:18
 Re: Steering wheel in reply to dave01, 08-14-2019 18:37:26
remove the steering wheel and key then remove the big nut on the housing and just screw it out the front. Mite want to have a machine shop drill and tap like JA said I will check on UPS to your zip today 8-15
FastFarmall
08-13-2019 19:24:47
If you buy or see a steering wheel, you will see it has a key way, and the shaft is cut for a half moon key,and put on a fine threaded nut you're in the driver seat!
Charlie M
08-13-2019 12:51:45
Both steering wheels fit but my A has the smaller one and my 100 has the larger one. To be correct you want the smaller one. Not sure what to do with the problem you have with the nut. It is held on by a big nut. You say your's is twisted off - like shaft it screws onto is broken off also? Maybe you will have to get another steering shaft.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
