Hey all, Back again with questions about the C I recently acquired.
This tractor has been converted to 12V with a Delco 10SI 3 wire alternator. The PO also installed an automotive style key start ignition switch with accessory feature, as well as a solenoid.
In an earlier post I had mentioned that alternator was not charging. I took it in to a local part store and they bench tested it for me and confirmed it was dead. I purchased a replacement 3 wire and installed it back in the tractor. Now it is charging perfectly.
After shutting down the tractor and doing some more work on it, I happened to touch the alternator and found it to be hot to the touch, almost too hot to keep my hand on it. So something was apparently back feeding power to the alternator. I promptly unhooked the pos battery cable and let things cool off.
In the mean time I inspected the wiring and all seems to be ok, but I did notice there does not appear to be a Resistor, or diode, or dummy light coming off the #1 terminal on the Delco. It just goes straightto the ignition switch. I will admit I have never wired a solenoid so I am not sure about the wiring on that, but all seems to work as it should. Is my problem that there is nothing between the #1 and ignition switch?
