Hello yesterday i stopped by to look at the 1066 again it has full flow of fuel to the
transfer pump on the back of the injection up but no flow on the out line , primer pump
had vacuum on it when I pulled it up so much that it pulled it back down , I pumped it a
dozen or more times not a drop came out on the out let side on the pump, can this pump be
worked on on the tractor ?? or dose the whole injection pump need to be removed ?? thanks
Bryan
Bryan
