Hello a friend has a 1066 that has fuel issues acted like filter replaced them ran fine, came to state it won't start, bleed and primed filters it will start , shut it down , won't start , it has good flow from tank to filter housing,( years ago I had a tractor that fuel line was plugged and acted the same way ) removed line from filters to pump seamed to evidence of algee in line (green paste ) cut open used filters very clean but paper elements had a green tint to them , lots of flow at bleed screw on top of housing when it is running , it gets air into the system some how , any ideas as what it could be ?? thanks Bryan
