Company Logo Shop Now
TractorLinks.com
300 Hydraulic question
300guy
07-15-2019 18:25:06
My 300 Farmall last Friday started leaking a LOT from the Hydra-touch valve area. I did not have time to really look for the leak, but it is above and to the left of the tach opening. From what I could see it looked like it was behind the ammeter area. Trying to get the small dash with the gauges attached out far enough while trying to sneak a look to find the leak is a real pain!!! I have had this apart several years ago, overhauled the valves and sealed everything up. It has been leak free since then until Friday when I was doing a lot of dirt work with the loader. Anyone have any ideas with the location of what the leak might be from? I know a lot more people out there have hundreds of hours working on those nicely buried valves!!! The major problem is the tractor is 2 hours away, so that creates a problem for working on it.
Chris NW Ind
07-17-2019 13:38:43
 Re: 300 Hydraulic question in reply to 300guy, 07-15-2019 18:25:06
No way around it, the stacked valves are a pain to work on. When I do my 450LP o-rings I will be changing every single one in there, all at the same time. Must be near 50 o-rings between the valves, pipes and relief/regulator. When I did my 450 gas, I stupidly used a slightly undersized o-ring in the last valve. That started leaking pretty so quick. Don't forget the o-rings and clips for the steering priority valve plugs. Those seem to blow out at the worst time. The IPLs will have the oring dash numbers so you can have them on hand.
Chris B.
wayne in mn
07-17-2019 05:18:59
Check for oil coming from the vent. With heavy use the oil may overheat & foam up.
You are using Hy Tran??
Roger in Wisconsin
07-16-2019 04:54:01
Disconnect the battery before you dig into it.
DeltaRed
07-15-2019 21:29:35
That is a 'stacked' valve setup. There are a 'bazillion' O rings there. Your leak could be any one(or more) of them. It might ever be hose.It's pretty much impossible for us to tell you "where".Take off the hood and cowling and look.
CharlesTX
07-15-2019 19:50:43
The valves have orings where each valve joins the adjacent valve. Their is also a relief valve that has orings. I replaced all of the orings which slowed my leak. The valves also have orings which require taking the valve apart. I did not replace the valve orings and still have some seepage but not bad. Replacing the join orings is not an issue getting access is an issue. I removed the entire good and moved the dash back for good accress
D Slater
07-15-2019 19:40:18
Could be several things without knowing exactly where the leak starts. Check to make sure the little line to oil pressure gage is okay. Several had the oil coming from there instead of hydraulics that I repaired.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
