Farmall & IHC Tractors Discussion Forum |
farmall 230
Author |
[Modern View] |
460anger
07-13-2019 04:59:57
just drug home a wide front 230 have a couple weird things going on the serial number plate says modified 230 next line 945 jcr 501 has a really nice 3 point on it not sure what the serial number means any ideas ?? thanks
460anger
07-14-2019 07:03:24
Re: farmall 230 in reply to 460anger, 07-13-2019 04:59:57
ok thanks for the info thought it might be worth saving but i looks like it goes for parts instead thanks again
worm
07-13-2019 08:22:01
CR stands for Chisholm Ryder. Should have a wider front end axle tube than standard and rear axle housings are wider than normal and has a snap ring on the end of the axle. Probably was a green bean picker once.
Janicholson
07-13-2019 05:05:11
Many were delivered to specialty companies to create tractors or specific use power sources. From Bean cultivation, to ginseng farming, modifications were made. Speed ranges in transmissions, creeper attachments, long axles, drop axles reversed drive trains, shortened lengthened. Jim
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
