So #1 is this a 12 volt system with 2 6 volt batteries or a 12 volt system with 2 12 volt batteries??
#2 how hard is it to remove the injectors so as to check for water in the cylinders and or add ATF so as to free up sticking rings. ??
From what the guy said this is a true diesel not like the TD6 where it starts on gas and then switch to gas right?
How hard is it to find parts??
Thanks
Thanks
