khouse6
we notice that when we leave gasoline in a tractor tank, that it gets gone. do not believe that it is stolen. hmmm
first thing is to make sure your shut off valve is closed. if you have a small leak through the carb with breather hose attached you may not notice it. over a period of time it will evaporate. same thing if your gas cap isn't sealing correctly. I suspect its one or the other.
Put a piece of clear packing tape between the cap and the tank body on the far side of the cap, small piece is good. Kidnapping gasoline is popular. Jim
A lot of good comments by others, but I would guess it's evaporation, especially if it's gas that was bought in the winter, it vaporizes at a lower temperature. And be sure you have the tank valve shut off when not using it.
I kinda think the same thing happens to me. I brought it up before and the consensus was it was dripping out. I am parked on cement and I always shut the tank off and it never shows up anywhere. I started putting a vinyl exam glove over the gas cap and it stopped. The glove is usually inflated like a balloon, hope I'm not pressurizing something that can't take it.
