Bob Purinton
I have a 1960 McCormick International tractor with the diesel engine.
The glow plugs quit last summer. I finally had the time to fix them and got a set. I replaced all four of them and cleaned the wires and other contacts with sandpaper and contact cleaner. Put everything back together and they still don't work.
Now, the problem is that there is power going to all four glow plugs. Whether the key is turned off or on there is power to the glow plugs.
I thought, OK,there would be if they were grounded when you needed them by rotating the switch on the dash.
I tried rotating the switch on the dash and there was no change in power. No resistor on the dash turning red or anything.
With the key off or on there is still power to the glow plugs. BTW 12.9 volts at the front plug and 12.4 at the rear plug.
Is everything OK and it's just a lack of understanding on my part or do I have a problem?
Thanks.
Thanks.
