drakeffa1086
New User
Hello I am working on a 1466. Tractor was well over past due for a clutch and TA over haul.
I put in a new TA and flywheel pressure plate and throw out bearing and all new bearings in TA housing as well.
Got her running clutch adjusted trans break adjusted all with spec sated in service manual. also adjusted TA dump and clutch booster.
everything works perfect however at idle I get a noise coming from the clutch housing area. as soon as you push in the clutch sound goes away so I was thing the throw out bearing was growling. as soon as you rev it up clutch depressed sound goes away as well.
I was just wondering what else it could be making that noise. I was just going to take her for a test drive and break everything in
just wanted to know your guys thoughts thank you in advance
