I have an International B250 which has a Front End Loader on it.
I have fitted a Post Hole Digger on the 3 Point Linkage on it and I am using a double acting hydraulic ram to assist the digger go into the ground.
To feed oil to the ram I have fitted couplings on the tilting of the bucket control so that I can plug in either the tilting of the bucket or the ram for the post hole digger.
I had a ram set up for the digger which worked, but I found a different double acting ram that would be more suitable for the purpose.
After I swapped the hoses from one ram to the next; when I tested it, it would not work.
I checked all of the controls and attempted to operated the 3PL as well and nothing worked.
Does anyone have any idea as to why this is happening and what should I be doing to get everything to operate again?
