I have asked a similar question in the past.
The fan assembly on the Super A contains about a half cup of oil per the users manual that I have (1947 version).
To fill the fan assembly with oil there is a #10 screw that you remove to put the oil in. I tried to use a oil squirt can to fill it up, but I only managed fill the tube up where the screw goes so that no air would come out and no oil would go in.
What have you used to successfully fill the fan assembly?
