I have a starter on my 1940 A that has a single stud sticking out from the side. That connects to a foot push button primary wire (no relay) it seems to be a farmall design. I have seen starters with a saddle switch that has a linkage for a pull rod. Mine has no mounting holes for the saddle switch and the stud is at 2 o clock.
Is there a way to convert mine without buying a new starter? I wish to be able to depress the clutch with my foot and use my hand to start.
I can make the linkage no problem.
