PeterS Plow ID
Cedric
That is a H-90 plow designed for the Farmall H. It was attached to the rear axle. It had a friction break beam for a safety measure. A later version, the H-190, had a solid beam with cushion springs at the front of the beam, similar to the A-192 setup. The plow was raised using the Lift-all.
I restored an H-190 several years ago but no longer have it, but I do have the Owner's Manual for both plows. Sid.
Cedric, thank you for the info. I have one that I just bought. I will try to post a pic. Does it need a lift cylinder also? I did not get one with purchase.
Thanks very much!
Peter.
Yes, it is requires a power cylinder. If you would like a copy of the Owner's Manual I can email it to you. Sid.
