I took the gov cap off. I found that that stud that is sticking up between the 2 pieces on either
side of it rubs on the L side slightly, looking at it. I also found that the top link wobbles in
the housing. I took the inside nut off but but the piece that fastens to the spring in back dosnt
want to move inward towards the side of the cap. I also found the bearing is shot
#1 Can I move that inside piece that the spring is on either in or out. In to get it a tighter
fit, OR out to take the outside arm all the way out and figure out a way to shim the shaft running
from outside to inside
#2 How do I adjust the arm going to the carb that is off the other side of the engine from the cap.
Thanks for any help
Thanks for any help
