Wicksfield
A few days ago, we were discussing that goofy hydraulic fitting under the battery of my 656. It needed to be tightened but the tube nut was seized. Not wanting to disassemble the complete tractor to remove the fitting, I cut that fitting above the tube nut with a Dremel. I was then able to back out the nut and remaining tube. Side note, the darn thing is discontinued so had to have it welded back together and of course the tube nut is now free.
Question(S). Did you know that "Y" fitting has a restrictor in it? Has about a 1/16 hole in the restrictor to allow oil through. Did you say that fitting draws oil from the sump if no power but still needed steering? Because, if this thing gives me trouble again I'm going to eliminate that fitting, connect the hoses, and install a plug in the hole.
Thanks for your response.
