IHdealer'son
A few weeks ago I brought home a 2001 loader that was removed from an I424 and want to mount it on my I504U.
Although the axle mounting is quite different, it will set the subframe at the same height as the 504 version of subframe, it will just not be easy/convenient to facilitate removal and reinstall.
My question relates to the forward (above front axle) mounts/rests for the subframe's bayonet (that's what IH referred to it as anyway). If there were some of the proper 340/504/460/606IH forward bracket/rest s available I'd be happiest to purchase a pair, but -nobody- is interested in separating individual parts from a loader assembly, so I'm going to work with what I have.
I don't doubt that I can re-utilize the 424 bracket parts that were included, but I need a measurement of height above some unchanging horizontal plane (frame casting below radiator area?) so that I can prop the subframe up and make a suitable measurement allowing me to produce a set of adapting plates/brackets.
