Wicksfield
I have an oil leak under the battery on my 656. It appears the leak is coming from fitting assembly p/n 404253R1. The fitting is like a "Y" configuration where one end has a tube pipe fitting that screws into the top of the transmission. The other ends of the "Y" fitting have hoses that attach. The fitting was loose in the transmission and of course, seized to the tubing. Will have to get a new one.
Question: Where the tube pipe fitting screws into the transmission, there is a hose that I can see still in the transmission. This hose would fit around the tubing. What is the deal with this hose in the transmission? Should I pull the hose out a bit to connect in on the end of the "y" fitting first? Is the hose just held on to the tubing by compression?
Sorry don't have a picture and I know this is confusing. Hope someone knows what I'm talking about and has been there, done that.
Thanks for your response.
