khouse6
140 farmall governor , is not operating. have to feed more gas by hand. what is the most likely problem? and can the governor cover be removed, without removing fan shroud?
Some say you can remove the governor without removing the fan shroud, I can't. Take it apart and see whats wrong and post back here. Keep track of the bolts as toy take them out as the are different lenghts. Be careful not to pull the governor shaft out because you will unmesh the gears and loose you ignition timing. Then we will be on to an entirely different subjuct.
Dave
