C169 motor for pulling
Wendell1167
New User
Hey guys new guy here looking for info on gaining hp in my 300. Would like some help or info on running no sleeves in the block. Pistons seem to be hard to find. Any info is appreciated.
Well since you are bent on destroying a engine all for the sake of that bragging wright trophy at the coffee shop on Monday morning and you need help on BUILDING a cheater motor . First off ya need someone that knows how and all the in's and out's . Next ya need a progressive size engine part size book . Then ya need a BIG legal pad and a stack of pencils , some procession measuring tools as inside and out side mic. calipers dial indicators . a total machine shop and the big thing ya need is to be 3/4 crazy and play Star Trec. and go where no one has gone before . and be ready to make lots of spare pieces and parts. Then the other things that come into play , (1) be willing to waste and engine on each pass , (2) have a bottomless piggy bank . And the next big thing here is NOT taking advice from your competitor even IF he is your best friend. I have built some wild engines just from DUMPSTER DIVING literately . I E one M M engine i built for my accountant . All parts other then rings bearings and seals and gskt. and some of them were custom made came from the bottom of scrap dumpsters going from 335 cu in to 609 cu in and make that all fit into two totally scrap blocks .
A 300 Farmall is usually between classes. To heavy for some and not heavy enough for others. Over bore sleeves,
shaving the head about .080, and an electric fan, no operating generator, a reground 350 cam, and some manifold to
head matching is do able, and will cost moderately compared to finding the correct pistons with the bore you choose,
and the piston pin to piston top distance perfect. A stroker crank and running in the block work, but as the vet
indicates, it is a 10 dollar trophy. A pulling tractor that wins on several tracks is like a high value race horse.
You need to keep feeding it and you don't ride it very far/often. Jim
(quoted from post at 13:49:10 06/06/19)
Listen to the Tractor Vet. Please do not destroy that engine by NOT using sleeves.[/quot
Ok then how about some helpful information on getting some hp. Maybe 350 sleeves and pistons
You would be a lot better off finding and old "M" and work your way up you would be competitive in more classes, Better yet find an "M" with the low low gear set. As others have said you will be limited in classes. I pull a Super C with a c-153 engine from time to time and find I can really only pull in 2 weight classes and be compeitive and if I really tell the truth I am only real OK in 1 class. But the fellows with old "M" tractors seem to pull more classes
I think you guys are ober reacting about saving a C169 engine....they ain't very rare! if the guy wants to build it I say go for it but a C175 in an H as a starting point would be my suggestion
I have a C-169 in my H, running around 120 or so hp. The bore was completely cut out and
4" sleeves installed. Lot of crank, cam, and head work, and a lot of $$$. first off you
need to find a compotent machine/race shop who knows how to do the work required. E-mail
and i"ll give you specs on the motor.....Joe
(quoted from post at 07:12:18 06/08/19) I have a C-169 in my H, running around 120 or so hp. The bore was completely cut out and
120 hp in an h. That sounds impressive.
If you went sleeveless what would you do
about counter bore ? And there prably is no
such piston. Plus you run risk of hairline
crack in bore and water getting in oil.
Sounds like a nitemare
