560 Diesel Clutch Replacement
BudKaiser
Ok I read my IT Manuel on main clutch replacement and it says to drain coolant just wandering why? Also I need to disconnect power steering lines I don't think I should have to drain the hydraulic fluid do I
Everything else seems pretty straight forward on R and R of clutch. I also see on this site and this site only several different throw out bearings all other sources come with a clutch kit consisting of
clutch,pressure plate, pilot bearing,throw out bearing and line up tool. Why do they not ask for a measurement of the throw out bearing.
temp sensing bulb has to go with rear half power steering pressure line will drip from pump manifold just place a pan under it don't need to drain hyd
t
If the temp gauge is working and installed properly that will have to be removed from head. Prabably would just have to drain 2 gal
