Ok I read my IT Manuel on main clutch replacement and it says to drain coolant just wandering why? Also I need to disconnect power steering lines I don't think I should have to drain the hydraulic fluid do I
Everything else seems pretty straight forward on R and R of clutch. I also see on this site and this site only several different throw out bearings all other sources come with a clutch kit consisting of
clutch,pressure plate, pilot bearing,throw out bearing and line up tool. Why do they not ask for a measurement of the throw out bearing.
