Was given an old Mayrath 32 ft conveyor that sat out in a pasture for decades un used after local feed store got an auger truck. I put a PTO hook up on the drive shaft and for last few years I Have been using it to load grain from hopper bottom trucks into our feed bins a few times a year. It runs ok but not sure how fast to run it. Also the drive chain and the conveyor chains both seem loose. The conveyor chain has what looks like adjustment nuts on a set of spring loaded bolts at the top but they don t seem to do much. For now I just throttle up until it rattles and then back off but it takes about five hours to unload a 25 ton truck. The bearings all seem ok the rattle seems to come from the chain skipping on the drive sprocket at the bottom. Would sure appreciate some input or an operators/service manual.
Thank you
Aubrey
Thank you
Aubrey
