Farmall Super A mower
John
04-05-2001 04:49:36
I want to mount a belly mower to my super a. All I have is the deck and I'm not sure what make it is. I would like to know how they are mounted at the rear of the tractor. I have seen some pic. but none from behind. If anyone can help it would be greatly appreciated. Thank you
RON/PA
04-06-2001 03:37:50
 Re: Farmall Super A mower in reply to John, 04-05-2001 04:49:36
JOHN, I have a super A with a 5 foot woods belly mount mower under it, mine is an old model. If you have not received the info that you need by friday evining, e-mail me and I will try to take some pix on saturday and send them to you. LOL RON/PA
David A
04-05-2001 06:40:52
The Woods is mounted to the final drive housings. There is fairly substantial frame that sits between the axles and bolts into the front holes of the housings. It does two things. Supports two peices of channel iron pointing toward the middle of the tractor that bolt to the mower deck. It also supports two drive belt idler pulleys that serve to turn the belt from the PTO to the deck and are slot mounted to adjust slack. The Woods literature has some good pics.
David
