Cub hyd. pump notpriming
Put some air pressure int the fill hole (maybe 10 psi at the most) Run the engine and move the levers to bleed air out. If it had oil in it when put back together, it should be OK. if it was dry, open the suction line and fill it with hydraulic oil to keep it from running dry. Jim
Hi, Jim
Went out this morning to try it after sitting
all night, & she primed & works as it should.
Thanks for the reply, Jim
Jim
