Bud Kaiser
Thanks for all yall's responses. I took the linkage off and seen for myself that the T/A does not seem to effect the clutch operation. I then adjusted everything back to spec and clutch and T/A work fine. It is working ok now ( do not understand why sometimes ok then a few days later grinds when putting in gear but I did idle it down to from 750 to 600 rpm"s that's as low as it will go) but I will try to make thru hay season then put a main clutch,pressure plate, throw out bearing and pilot bearing in it. With all the junk rebuilt parts where are yall having the best luck on clutch parts?
