slifnom
I have 2 dead batteries on my 560 D. What are the proper cca for this tractor? Nothing in the operators manual! The batteries on it now are miss matched. Thank you
I have one battery in mine. a heavy 12 volt that has about 900 cca. there is room in the battery box for 2 batterys this size. When I got this one I thought I might have to go back for a second one and I have the cables to do it, but the one has been good for me. I don't normally start it in the cold times but it has plenty of power.
I presume your talking about the 2 6 volt battery's it came with. they come in 650 cca for the small ones , or you can get the big ines at about 950-1000 cca. the big ones fit as they are the size of a 12 volt batt. to keep it original it had the smaller ones to fit the battery hold down top.
or put in one 12volt , or even put in 2 12 volt in parallel. up to you.
I have 2 batteries around 800 cca each in my 560 diesel, the same size I put in my dodge cummins trucks and they are 5 years old and it still starts just fine
