F20 variable governor adjustments
dep
Hi, does anyone have a scan of the procedure for adjusting a late F20 with the variable speed governor??
Not sure which type of governer I have, but I do know I adjusted it once. From what I can remember, a minor
adjustment affected it alot. And it was kind of a treacherous procedure. Seems like I was always needing 3 hands
when I was trying to do it. Kind of wished I wouldn't of tore into it, after I took it apart.
Original or aftermarket? I have a copy of the Heisler instructions, I can scan if that is what you have.
(quoted from post at 19:55:07 05/30/19) Original or aftermarket? I have a copy of the Heisler instructions, I can scan if that is what you have.
I have the original variable speed governor that was on the late models.
