International 2510b/574 heavy duty clutch
jhholl
New User
This message is a reply to an archived post by Michigan Iron on May 21, 2016 at 09:45:18.
The original subject was "Re: International 2510b574 heavy duty clutch".
Hello, I have an International 2510b
loader and I'm told it needs an engine
rebuild. Do you know if this tractor needs
to be split in order to rebuild that
engine?
I know you can not drop the rear main bearing cap without splitting it, but you could put pistons,sleeves, and rod bearings in it. Mark.
