plow paint scheme
I'm in the process of painting an International model 60 plow. I've tried googling some pictures that would show how it should be
painted. I know the wheels are farmall white and the axles are blue and the main frame is farmall red. Just need a good picture to
go by. Anyone got any?
It's not a 60, but a late No. 4,
I am finding some blue on it that looks original. Tail wheel assembly and main axle shafts, and back of plow shares are showing
hints of blue paint.
Here is my view on parts colors:
Red - Frame, adjustment handles, and shanks and shank mounting hardware for coulters.
White - All three wheels. This should be IH 901 White (To my knowledge not available at your local CIH dealer), not IH 935 white, which is available at your local CIH dealer.
Blue - Axles, trip clutch assembly, springs inside the plow frame, all moldboard parts, tail wheel assembly less the tail wheel itself.
Black - Hitch, coulters, coulter yokes, and jointers, if used.
The picture is an IH #8 plow. The wheels are protected with pieces of tractor tire inner tubes until it gets to its final resting place. You are correct in that many times one can find remnants of original paint color on protected areas of parts. Hope this helps.
(quoted from post at 10:03:58 05/28/19) I am finding some blue on it that looks original. Tail wheel assembly and main axle shafts, and back of plow shares are showing
You must have an early one. I have two #60 plows and there is no hint of blue anywhere.
