Company Logo Shop Now
All this for an alternator belt
Southern Ray
05-27-2019 13:05:14
My alternator was slow to start charging when I cranked the engine. I had to rev up the engine to make higher RPMs to make it start charging.
I knew the belt was loose but kept putting it off. Last week it just quit charging. I had no more adjustment room to tighten it. I needed to put in a new belt.
I needed to remove the fan belt before I could remove the alternator belt. The water pump pulley needed to be widened to loosen the belt.
Getting the nut off the set screw on the pulley sheave half was easy, but the set screw was locked in.
No room to get anything in there, not even a small vise grips. I had to pull everything off to get the room I needed.
I was then able to grab the set screw with a pair of vise grips and get it out. Now the two sheaves were frozen together.
I then needed to remove the fan and the pump drive pieces. Finally with everything cleared away I was able to work on the sheave halves.
With a solid brass punch and a small hammer, and with plenty of penetrating oil, I could then finally free up the sheave halves.
Finally after three days working on it everything is back together and running again.
rustyfarmall
05-29-2019 07:49:59
 Re: All this for an alternator belt in reply to Southern Ray, 05-27-2019 13:05:14
I've also been known to "roll" the belt off of the pulleys when all else failed.
Old-F20
05-29-2019 07:00:47
you can fish that alt/gen belt over the fan blade one blade at a time. I just put a new generator belt on my OS4 the other day. theres no need to take the radiator out to do that job
Janicholson
05-28-2019 14:32:06
Next time. Jim
mattofvinings
05-27-2019 19:32:02
JMO but once freed, I would coat the threads with anti-seize for the future. Too much will of course foul the belt but it doesn't take much to keep the halves loose.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: 1953 Ford Jubilee SN#70068. I can provide pictures upon request and please only serious inquiries for the tractor. This tractor has been well kept under a shed. [More Ads]
Copyright © 1997-2020 Yesterday's Tractor Co.
