Super a touch control
gidtex
Installed a kit in touch control and new o ring in pump.have only 200 pound pressure.didnt check pressure before installing kit.pull head off touch control and notice a lot slack between safety valve sleeve and bore.does safety valve piston seal on safety valve sleeve because small hole in sleeve is bigger then the small end piston thanks.
