Farmall Super A oil and gear grease amounts
Mtjohnso
I have two different manuals for the Farmall series of tractors. None of them show what oil or how much oil goes into the cavity in the Fan Assembly. I assume maybe 30 weight and maybe a cupful! recommendations?
The transmission takes 5 quarts of 90 weight although I do not see that weight in the service manual.
The bull gear area I do not see a gear oil or grease capacity or weight specified. Recommendations? Same for PTO or does PTO get covered by the transmission?
A cup is too much. Squirt a bunch in there then rotate the fill hole to about 45 degrees and let it drain out. 30W is a good choice.
pto and tranny run in same oil . you say bull gear, is that part of differential? if so , covered by transmission oil
the drop axles, fill to bottom of fill plug.
the fan assembly, use 30 weight, not too much, and then turn upside down and let excess drip out.
(quoted from post at 21:15:22 05/25/19) A cup is too much. Squirt a bunch in there then rotate the fill hole to about 45 degrees and let it drain out. 30W is a good choice.
<img src = "https://i.imgur.com/KxF6v1q.jpg">
(quoted from post at 00:53:11 05/26/19)
