42 H Carburetor issues
42h2019
New User
Have a 42 H I have been threw the carburetor least couple times. It
runs but will blow gas threw the exhaust. What am I missing?
If you have gas coming out the exhaust good chance you have a stock or out of adjustment exhaust valve so one cylinder has low of no compression and the gas is going in then out the exhaust
I would do a compression check. You should should never get gas blowing out of the exhaust. That is not a carburetor problem. Old meant to say a stuck valve.
OTJ
I doubt you have gas coming out the exhaust , IF she is blowing wet black spots all over your paint job it is condensation build up in the muffler .
