M pto shaft seal
bass
gonna replace the oil seal on the pto shaft on my M. any tricks or tips on changing out the seal.
comments welcome.
bass
(quoted from post at 07:11:38 05/25/19) gonna replace the oil seal on the pto shaft on my M. any tricks or tips on changing out the seal.
comments welcome.
bass
The only trick I have for this is to park the tractor pointing downhill so that you won't lose any fluid when you remove the cover to replace the seal. Also if there is a groove in your shaft from the old seal, you can place the seal a little deeper in the cover so that it seals to a fresh place on the pto shaft.
