INTERNATIONAL 656
Head studs from CaseIH will wound your wallet. Studs from Fastenal, also, Summit Racing ARP studs are very good. Jim
If your having head gskt. problems then you also have other problems . (1) your head needs refaced and valves need redone.-(2) you may have sleeve problems where they are not set correctly , (3) you may have also a deck problems of being warped . Unless the head bolts are pitted /rusted / stretched then the stud is not going to solve your problems . This is not a high performance race engine and you over thinking the wheel. When the proper gskt is used and correct torquing is done correctly the stock gskt and head bolts last darn near forever.
