1586 transmission brake
I have a 1586 with the gears grinding to work on. I'll plan on adjusting the transmission brake linkage, but I'm wondering if that brake pad can be replaced without splitting the tractor?
Appreciate the help as always, Bob
If it is like a 1086-then yes. Just drain the transmission fluid, and remove the housing. not a bad job. Mark
OK. Thanks a lot for the response and information. My 806 has about the same thing as it looks from the outside and that has a bottom pan that I'm guessing I could take off.
I 'll try adjusting it first.
Thanks again, Bob
