Hydraulic leak.
54SuperC
New User
Not sure where else to go on this. Was leaking out from the block. So I took it off replaced the o rings and still leaks. So I took it off again and put the next fatter size of o ring in. Still leaks. Not sure where to go from here.
I have found over the years that you can not tighten one end up then the other, I start both ends get bolts in then go back and forth snugging as i go until all are tight. Did you use the blue orings from Case IH?
Looks like someone has layed some brazing on that line
at some time. Leak could still be coming from that area.
There could be a small fracture in that block beside the
o-rings letting pressure seep out.
Jim
definatly use right orings...an i agree with 450 check that brazing on line.....................dewy
