Nicholaus Sowder
I need some advice on my International Cub Lo Boy. I?m having a hard time getting it to start. I have put a PerTronix electronic ignition on it, I had it start and die with me once. Now the starter will not even turn the engine over, so I had the starter rebuilt. Still the same thing. It seems to me like the bending gear is not engaging the ring gear. I have a new coil on it, new spark plugs, fresh gas and new spark plug wires. The spark plugs are gapped at thirty thousands. PerTronix says to go seven thousand above the normal gap. Any and all advice is greatly appreciated Thank you
