F460 hydraulic line hose needed
Guys - I need the big Hydraulic home for my Farmall 460. Does anyone have one I can buy or do you know where I can get on. Mine is leaking
badly. Thanks in advance. John.
$465 at your local CaseIH dealer.
Alternatively, you could have a hydraulic shop fix it. They may be able to install a new hose on the tube. If not, have them cut the hose off the tube and weld a standard threaded fitting on the end of the tube. Then they can make up a hose with the appropriate ends.
No not hard to change. The top fitting is an overgrown flare JIC fitting one bump on a wrench should get it going and the bottom is three bolts.
